1 - 20 of 47 Posts
Hi guys! I am new on this forum,i've bought a 2010 Jaguar XJ(this is my first ever Jaguar).Me and my wife we love it,stunning car,no mechanical or electrical problems except the rust that is visible from outside whe i open the sunroof! I never seen anything like it,i need your help/advice guys! How or who can fix this problem? I was thinking of doing it myself but i dont know how to take the outside glass panel off so i can have good acces to the affected,rusted area
Welcome to the forum.
Top Tip, don't remove the glass panels!
Fully open the sunroof and sand off as much rust as possible.
Then treat with a rust converter and then paint over with black Hammerite.
My sunroof rails are ok and I just apply a coat of copper grease every year.
I found a video on youtube reviewing XJs the other day. The reviewer (a foreign chappie, sounds a bit like a meerkat) remarked that the sunroof runners of early XJs had a rust problem, but post-2012 they used a different metal and the problem was eliminated or drastically reduced. Unfortunately it looked to be a big job to remove the sunroofs and their frames. The reviewer suggested it might be better to treat the rust in situ, and repaint them every now and then. Sorry I couldn't be more positive.
About 1 minute 5 seconds into this video.
Reactions: ArtyH and JimC64
When I had my 2010 XJ I had similar issues which are not uncommon as suggested.
I did a bit of reading and bought a product Bilt-Hamber Hydrate which I never got round to using as the car was returned for other reasons.
It seems to get good reviews in the automotive sector, but there are many products that will do the job.
I guess those areas you can't reach will always give you a bit of a worry but something you may have to live with.
2017 Autobiography
Hi sir, and welcome aboard.
Pull up a stool, get comfortable, tell us more about the car, and post some pictures!
My solution was to leave the roof closed and get used to the squeak, until the time came to get a newer one (car, not roof). You will come to learn, however, that my solutions to issues are not always optimal.
Filth. :ROFLMAO:
Reactions: WelshBoa and #steve
Hi there, you've been given the best advice already it seems.
Never seen the glass panels removed, seems like a very big job, best done as best you can in situ. I've been lucky in that regard, mine's are in decent shape and looked after / treated regularly
Best of luck
Could strike a swan vesta on that!
The Titanic has less rust. :ROFLMAO:
2017 Autobiography
Discussion Starter · #15 ·
Thank you Steve!
Discussion Starter · #17 ·
Hi! I fixed the problem myself 2 months ago.I removed the glass panel( the sliding one) so i can acces the full are where the corrosion was.Sanded down,used fiber glass on the damaged area,sanded down the fiberglass,primed then sprayed 3 coats of black matt on the top of that! Let me know if you got any questions!
Hi! I fixed the problem myself 2 months ago.Removed the sliding glass panel so i have acces to the full corroded area,sanded off the rust,applied fiberglass on the area and sanded smooth.Then i used primer and at the end i sprayed 3 coats of matt black.Let me know if you got any questions
Car Vehicle Automotive lighting Hood Motor vehicle
Car Vehicle Wheel Tire Motor vehicle
Window Water Hood Car Road surface
Car Vehicle Plant Window Automotive lighting
Hood Tire Car Wheel Automotive tire
Textile Purple Rectangle Grey Comfort
Car Land vehicle Tire Wheel Window
Hood Wood Tablecloth Linens Automotive design
Land vehicle Car Vehicle Automotive tire Tire
Window Vehicle Building Wood Car
Discussion Starter · #20 ·
How did you get the glass off?
Theres two plastic covers on each side,you can unclip them when your glass panel is fully open.once you done that you will see 3 torque screws on each side,you can remove them using a t20 or t25 screw bit.with somebody's help gently lift off the glass panel and place it somewhere safe
Automotive lighting Wood Bumper Automotive exterior Grille
Hood Automotive lighting Automotive tire Motor vehicle Bumper
Window Automotive lighting Hood Automotive tire Motor vehicle
1 - 20 of 47 Posts
