XJ6 4.2 engine to early BW autobox
SV8Predator
Active member
1,078
24
33
Further up the creek.
Just to be clear, you want to fit a 1950s DG gearbox to your 1980s S3 which originally had a Borg Warner Type 66 gearbox?
So completely different, very old-fashioned, different bell housing and gearbox, different spline, what a major undertaking.
Why would you want to do this?
If it's to fit a 4.2 S3 engine into your Mk 8, then use the gearbox that comes with the engine.
If it's to fit a Mk 8 DG box into your S3 XJ6 (which seems to be what you're asking), then (again) why?
Theregistrar
156
16
W.Midlands
You are assuming the 4.2 comes with a vehicle .
Simple - cost ! My Mk8 has only done 41,000 and have a 4.2 rebuilt engine
to replace the 3.4 which must have been an anchor in another life.
The 4.2 never came with a box so why spend money when I may have an option of
using the one I have ??
Thanking you in anticipation.
SV8Predator
Active member
1,078
24
33
I'm not assuming anything! Hence the two questions in my previous post!
Fraser
Senior member
1,693
65
53
Crewe, Cheshire, UK
Physically, the engines are the same size, and about the same weight, I would estimate, but this will still be a major job, so are you ready for that ? Might be better to find a BW box that fits your Series 3 engine, a Model 65 or 66 will fit and maybe an earlier box that went on the Series 1 cars. There must be a few around still. That way the links to the rest of the car will be less daunting, (fuel, coolant, electrics etc).
