I have managed to get a set of rear shockers for my 95 xj6 --If i remove the four bolts from the top plate and the bottom bolt from the shocker --will i be able to remove the spring and shocker together just by lowering the hub assembly (is there enough space ) and can i use the weight of the car to compress the spring for re-assembly --some advice before i start from those with experience can save lots of skin from knuckles !
