I have raised this before and didn't really resolve the issue. I have 3 Jags all with the 4.0L V8 engine. A 2002 XJ8 SE, A 2000 XJ8 Sovereign, and a 2000 XK8 Coupe. I drove the 2002 SE for about 6 years and it's now covered 250,000 miles - but it always was not very responsive to relatively small throttle pedal movements. I always took that as a function of the 'fly by wire' throttle control. If I booted it - it was off like a rocket! I decided that the SE wasn't going to last much longer so I bought a 2000 Sovereign. The difference in throttle response was immediately obvious - touch the pedal and it instantly speeds up. Not overly happy with the Sov, I bought a 2000 XK8 Coupe and guess what - it's got the same sluggish response as the 2002 SE!
I was advised to adjust out any slack in the throttle cable and I did that. It did have an effect in that the pedal requires less movement before the engine responds, but whilst moving along, pushing the pedal down has little effect until quite a lot of travel has been taken up. It's almost as if the throttle cable is made of elastic! The year 2000 car though feels like pedal is directly connected to the engine.
I've done a bit of reading up and it turns out that (except in Limp Mode) the actual throttle position is totally controlled by the PPS (pedal position sensor) feeding values to the ECM, and the ECM feeding a voltage to the throttle servo motor in the throttle body which moves the throttle disc, the position of which is then monitored by the TPS - which feeds data back to the ECM. (Well that's my interpretation of the system). The shaft passes right through the throttle body, but the throttle cable end does not open the throttle disc - the servo does that. In other words the shaft is separated at the cable end - although it looks like a solid rod. The only time the cable directly controls the throttle disc is in Limp Mode - and that is restricted to 30% opening.
So the sluggish response could be caused by a sluggish PPS, a sluggish servo drive system to the disc, or the ECM.
Now to further clarify the problem - my 2002 SE had a Limp Mode event a few years back. I ended up buying a replacement throttle body (2nd hand) and put that on. Fortunately it worked and solved the Limp Mode problem - but the car was just as sluggish as before (or to be more correct I didn't notice any better throttle response). This might rule out the possibility that it's the throttle body. So is it the ECM?
Both the year 2000 cars were registered in March 2000, and are therefore probably Nikasil Linered. (The year 2002 car is of course steel linered). Jaguar started steel linered engines in August 2001. However, I don't know if either were replaced but, seeing as British petrol was low Sulphur from 01/01/2000, then neither should have a problem. For now I will assume both engines are fine mechanically.
I'm wondering if I can take the ECM out of the Sovereign and put in the XK8. Alternatively, most car ECM's have a removable EPROM with the engine mapping on. Does anyone supply these?
By the way - the word 'sluggish' is relative. The XK8 and 2002 SE only show up as 'sluggish' when you've driven the Sovereign.
