Only 3 where I’m from…one is retiring, one has 2-3 mths waiting list and the third one doesn’t want to look at it—some specialist he is!!Rather than guesswork it would be better to get the car to a independent Jaguar specialist in your area.
Tried but no joy—car doesn’t even try to start! 2 issues appear after a diagnostic test.. 1, column lock and 2, authorisation start control unit!! Have the car booked into an auto electrical centre-hopefully they can find the issue(s)—-have a decent reputation! Fingers cross!!Thx …will give this a go!
Welcome aboard Colm, sorry to hear of your issues........Hi.
Just joined today and already need help or assistance!
Bought a 2007 XKR a few months ago. About 8hrs of having passed its MOT the car wouldn’t start. I was told it may be because of ‘column lock ground authorisation’ and/or ‘start control unit’! Presently I have the battery disconnect as car lights were staying on and flatting the battery…when trying to start no lights on dashboard were lightning up! I’m not very mechanic etc minded so any advice will be greatly appreciated!
Another issue I have does anyone know where this wire should go -see pics?! Thank you.
This is worthwhile considering, may help give more info....Have a look on this thread.
There may be somebody who has a code reader in the near of you.
OBD Diagnostic code readers - members locations?
Hi, Add me to the list. Chessman Roydon Essex Jaguar Autoenginuity. Hello Chessmen, apologies if too much of a long shot. My 2003 XKR, at Brentwood, Essex needs diagnostic scanning (DSC fault/ABS & MIL ) and I saw on a forum thread that you may have an AutoEnginuity I could use. Is your...www.jaguarforum.com
Good advice, if you can ColmRather than guesswork it would be better to get the car to a independent Jaguar specialist in your area.
Hopefully this helps a bit!!Pity you can’t post the code numbers.
The autospark did this…they still appearThey are historic codes so worth clearing and seeing if they come back.
I refer you then to my other post #24The autospark did this…they still appear
