Boot showing open but actually closed and the car won’t lock
67K views 59 replies 30 participants last post by  AntF
Jaguar XF – Boot showing open but actually closed and the car won’t lock via remote.
Parked my car today got out and tried to lock it via the remote and the door buttons but got the blip sound to say a door was open. Checked all doors and they were closed. Got back in the car and the information centre said the boot was open? Checked the boot, but it was actually locked and would not open via the button or the remote. Gained entry via the boot lock with the remotes door key and closed it again, but still the car would not lock. Managed to lock the car via the passenger’s side door key lock and hoped when I came back everything would be o.k?
You guessed it - it wasn’t, so popped in to a nearby jaguar dealer who advised me that they have had a technical notice regarding this problem and he explained that the problem was a broken wire located in the rubber boot / pipe that connects the wiring from the car body to the boot lid on the right hand side of the boot.
As the car is now out of warranty he advised that the cost to repair the fault would be around £100. Being an ex-electrician I was a little surprised as flexible cables don’t normally break, especially on a 3, year old car?
I took it home and had a look for myself and there it was one broken cable, I put a though crimp on it and that was it job done. If your good at DIY it a job worth doing yourself.
Discussion starter · #4 ·
Re: Boot showing open but actually closed and the car won't
Hi,
Could be the same problem as I noted at least three other cables needing a repair but only one broken.
From what I can remember, pull the rubber boot out from where it goes in to the car and with a sharp blade cut the rubber that holds it to the cable - don't cut the boot itself. Then push it back in to the hole, but then push it further so the whole thing goes in to the car. Then pull the rubber boot from the boot lid and cut away the rubber that is secured to the cable. Then you should be able push the rubber boot back and you will be able to see the broken cable. I repaired it with a 1mm "Crimp" but you will need a crimping tool or you could pop in to Halfords and pick up a crimping kit.
Hope this helps
Steve
Discussion starter · #6 ·
Hi
The cable was completely broken and I re-made it via the crimp as discussed before.
I believe that because the cable loom is tied at each end of the rubber boot, the wiring loom can't actually move when the boot lid is opened / shut and hence the reason why the cable had broken.
I left the loom free to move after the repair.
Hope this helps
Steve
