Cigarette Lighter and Passenger Tail Light Don't Work -- Fuse Box Location 2000 XK8
4.9K views 9 replies 4 participants last post by  frankc
Hi! I'm new here. I am a former owner of a '76 XJ12 Conversion and a '78 XJ6L Conversion. I am loving my 2000 XK8 Convertible! Can someone point me to the location of the fuse box? Thank you in advance.
#2 ·
Welcome to the forum.
One under the bonnet and one either side of the dashboard (open the doors and you’ll see a lift of panel) also one in the boot.
G
#5 ·
Yes - 5 fuse boxes altogether.
One big one in the trunk / boot.
One on each side of the fascia - accessible with the doors open.
One towards the front of the engine bay - next to the ABS pump and module.
One on either the left or right hand side of the engine compartment (depending on LHD or RHD) - next to the engine and transmission computers.
The big one in the boot / trunk has a schematic for all the fuses in all the fuse boxes printed on the lid.
G
#6 ·
I think it unlikely that the two are related. The cigar lighter is fused through fuse #14 (20A) in the passenger side fuse box.
Have you checked the bulb and/or connections to the rear bulb - both sides go through the same circuit and fuse, so if one side works ................................................ ??
#8 ·
The fuse your looking for is in the fuse box in the gap of the open passengers door. Will see if I can find a link or photo for you. I do not think the cigar lighter, Jags have cigar lighters not cigarette lighters, has anything to do with the tail light. As suggested before it could well be a bulb. Before replacing the fuse however take a look inside your lighter. Mine blew and kept blowing any replacement fuses. Turned out to be a penny had dropped in there!
Here you go. I am pretty sure I used the Cigar lighter fuse to power my dash cam. http://www.jaguarforum.com/showthread.php?t=75123&p=858012&viewfull=1#post858012
#9 ·
A penny fell in the cigar lighter. I will check the tail light bulb. I spent yesterday afternoon doing a tuneup. The driver side cylinders are marked 8 5 6 7, rear to front. Would the passenger side be 4 1 2 3?
