So would probably need two 5ltr cans = £136-00 plus the Prep Flush £40, so looking around £176-00, quite a lot more that Antifeeze!
But is it worth that much extra???
No it is not. In fact I think its use in a V12 XJS would be a huge mistake. The cylinder heads will run considerably hotter than with water/antifreeze mix, even though they will not actually boil. This is because the 100% Glycol (what it basically is) does not transfer heat as well as water. So the underbonnet temps will be a great deal higher, as will the water jacket temps. This running hotter will mean that any water temp switched electric fan will need the thermostatic switch chnaged or reprogrammed.
Second, when a hose goes, you cannot top it up easily.
Third I defy anyone to get 97% of the water out of the system without dismantling the lot and physically drying everything, heater matrix, heads, block, rads etc etc.
Stick with water antifreeze, chuck in some water wetter if you like, and enjoy the car, says I, anyway.
