Jaguar X300 GUIDE to: Replacing a clock in an X300 (Blue LCD)
JSeaman
178
Step 18 - you can see that a conductive strip glues the ribbon cable to the display and board, this can simply be peeled away (if being replaced rather than squeezed back on)
Step 19 - The LCD screen simply unclips from the mounting bracket and can be removed easily
Step 20 - If only you could solder to the LCD screen you would be able to re-make the 28 connections however you will need to get some special cable to fix these connections. At this stage I decided to go down the path of getting a new LCD screen and eBay revealed a 12V LED clock for £10 delivered from China.
I bought "12V Blue LED Digital Electric Clock For Car Motorcycle" from a seller called topthinkstore, it was 9.99 and took a while to arrive (4 weeks) but is an economical way to go
JSeaman
178
Step 21 - First, the two tabs need to go - I just ground them off. This makes it a nice fit in the stock housing as shown in the last picture
JSeaman
178
Step 22 - You get a large green button for setting the time on this clock (press and hold for minutes of press repeatedly to change the hour), which I didn't want so I cut it off at a sensible length to allow me to wire it to the existing buttons (about 6 inches) and removed the sheath
JSeaman
178
Step 23 - I then stripped and tinned the ends of the wire with some solder and snipped them down to size
JSeaman
178
Step 24 - I wanted to use the existing hour button to control my new clock so chose SW2 (switch 2 on the PCB as shown). You need to solder opposite corners as shown in the second picture
JSeaman
178
Step 25 - Add a little solder to each of the pins then solder the wires on as shown. Use some hot melt to cover the solder joint and first centimetre or so of the wire for mechanical restraint
JSeaman
178
Step 26 - Now onto the display, the stock plastic film is quite large and, as shown in the first picture, bigger than our new display. A simple and very effective approach is to just use a permanent marker to black it out (you could paint it if preferred)
JSeaman
178
Step 27 - Drop the plastic film into the enclosure for the clock and apply some hot melt glue to hold it in place as shown. Ensure no glue goes through to the other side (if it does, let the hot melt cool and use a sharp Stanley blade to tidy it)
JSeaman
178
Step 28 - Pop the clock into place and secure with another dose of hot melt (make sure the clock is the right way up!!)
Step 29 - Now pass the 3 wires through the PCB as shown
JSeaman
178
Step 30 - Carefully pop the PCB back into the enclosure and make sure you don't trap any of your new wires when clipping it together
