map sensor live data 120 kpa
1 reading
13K views 19 replies 6 participants last post by  rjk1188
#1 · (Edited)
2.0 d. still having problems with map sensor p0105, put scanner on and getting 120 kpa at idle, any one know if this is to high or low, blip the throttle to 2k, reading goes up to approx 150 kpa no lights on dash, p0105 is pending
#8 ·
Is your MAP sensor located in the middle of the EGR pipe run from the intercooler to the EGR? Or, in simpler terms, is it way down between the engine and radiator on the left hand side when standing in front of the car and a bu88er to get to?
#10 ·
OK. It is not uncommon for the wiring going into the MAF plug to corrode giving intermittent connections and fault codes. I had this.
The MAF wiring goes into the big thick wiring loom adjacent to it. From there, inside the loom, it runs up towards the top of the engine.
What I did was to open up the loom on top of the engine (or rather near to the EGR) and identify the MAF wires. Amongst the colours will be two identical wires, white with green stripe. One is the MAF signal,the other is a temperature signal. After identifying and marking, I cut the wires going into the MAF plug, leaving length from the plug to make fresh connections. The wires were pulled up through the loom. From here I could see the corrosion. I cut out the corroded section and made a fresh loom to the plug - soldered and heat shrink sleeved connections, and the 4 wires then inside a fresh sleeve.
So, instead of the MAF wires entering the loom down low, they now run up near to the EGR and enter the main loom there. In future, I can simply detach the EGR pipe run at the intercooler and EGR ends and lift the pipe run out. The MAF loom will slacken as you lift out, and you can then easily detach the MAF plug. This is a vast improvement from trying to detach the MAF plug in situ with minimal access.
#11 ·
#15 ·
I don't know if this helps but I just found this on a Transit website - I guess the theory is the same (what complicates this is that apparently the f-super shows readings out by a factor of 10...
With f-super, some key bit of information:-
  1. BARO is air pressure, and is out by a factor of 10. So 100 is roughly 1000mb. (MAP sensor). Should be roughtly 99-101 depending on the weather and altitude. Note on images mine is 88 - thats because I was up in the Alps!
  2. MAP is manifold absolute pressure, and is in effect boost pressure. It is in effect a factor of 100 out! (see MAP sensor). On idle, it should match BARO (x10), and on revving to 2-3000 revs should read up to 14. (Boost pressure in PSI = (( 10xMAP ) - BARO ) x 0.145. So, if BARO = 100, and MAP = 14, then PSI = ( (10 x 14) -100 ) x 0.145 = (140 - 100) x 0.145 = 40 x 0.145 = 5.8 psi boost
Ford Transit TDCi, low power, low boost (p0235) - Fixed!
#18 ·
just checked my mates map sensor readings on a 55 mondeo tdci, 101 kpa engine stopped and at idle, revved up hard would only go to 160 kpa, mine is 116 kpa at engine stopped, 120 kpa at idle , revved hard saw 240 kpa, have ordered a new ford map sensor hope it sorts it out.
