Bluechem,
Is it safe to leave Oxicat in the petrol for a longer period.
My car runs off LPG but it starts and runs on petrol until the engine gets to about ETC 55 degrees when it switches over. I use about 1/2 of a tank of petrol ever 6 months. So, if I fulled the tank, added a can of Oxicat, it would be sitting in the fuel for about 1 year. Is that safe or will it cause any issues?
Certainly there will not be any issues with the Oxicat in the tank, but, I do a much better product for LPG conversions. The product is called Fuel System Cleaner and it will
1/ Stop the fuel from ageing, keeping it properly mixed
2/ Keep cleaning the injectors when fuel is used
3/ Clean the entire fuel system from tank to injector
4/ Mix in water droplets and carry them through the system.
You should not have so many issues with Carbon if you generally run on Gas, it is very clean and leaves less deposits. It does run 500 degrees hotter, and if not originally fitted with LPG as standard, can cause hard valve guide oil seals and burn a bit more oil. A simple seal conditioner can help with that problem if it occurs.
Cheers Ed, Regards
Richard
