Passenger (LH) door lock not unlocking with key fob.
1 reading
8K views 2 replies 3 participants last post by  RickG2021
Hi, Jaguar XF (X250) passenger door (LH) front doesn't unlock when pressing key fob. It will open from the inside manually. It also locks with the key.
Has anyone seen this issue before. I'm not sure if it is a problem with the door lock mechanism or the door control unit.
I have had the trim off and the cable is correctly attached. I checked all the cables and connections and everything is o.k.
With the door off and pressing the key, I can see the cable move but only a very slightly (not enough to unlock the door).
Any ideas?
J
