XJR on LPG
4.3K views 12 replies 7 participants last post by  Hairyjohn
Anyone running one? There's one for sale locally......
#3 ·
Only downside is the valve seats are very soft on the V8 heads, the valve seats recess and it's game over. Head rebuild time.
You don't see too many Jags showing this, as not many are on gas, but there are alot of RangeRovers on gas. Pleanty of cheap ones needing headrebuilds due to gas damaged heads.
#4 ·
Thanks for the answers - I guess a realistic idea of MPG would be good - I need to factor in what the extra costs in fuel might be.
#5 ·
The cost for the conversion was ÂŁ2,600. In addition you need to factor in some allowance for unleaded fuel as the engine starts up on unleaded and switches over once warm. In addition, you need to factor is some lubricant at ÂŁ17 per 1,000 litres of LPG. Also, the system requires servicing annually at a cost of about ÂŁ60. It soon adds up!
I worked out that it would take me approximately 18 months to break even after which I was saving approximately ÂŁ140 per month. At the minute,
it is costing me about ÂŁ40 per 220 miles instead of ÂŁ90 per 250 miles (very rough "before and after" values), without factoring in additonal unleaded, lubricant and servicing.
I had the same misconception that you get more MPG with LPG but you don't ..... you actually get slightly reduced MPG, about 18 instead of 20 in my case, but as LPG is approximately 50% of the cost of unleaded this is where the savings lie.
I cannot comment too much on the "valve seats" issue, but my understanding is that the engines are prone to this issue anyway so this is an additional risk you would take admittedly. I mitigate against this to some extent by running every so often on unleaded only in addition to the period of start up already mentioned.
Regards,
Brian.
#6 ·
Thanks for all that Brian -excellent info and much appreciated.
#11 ·
Last time I went on there they had CCTV inspection of the whole vehicle including underside. I guess if they know what they are looking for it would be easy to spot - then again, maybe not. Not the end of the world - I have to fly to France these days as her indoors can't spent more than 10 minutes in any car journey without moaning. Although I could work on taking the car whilst she flies :)
