Hi does my 2002 2.5MY have a PCV valve i cannot find it in the manual i have and cannot see one
Dave
Dave
Going back to your original post in this thread, here is a graphic of the vacuum line/hose connections and routing on the later version of the AJ-V6, courtesy of "rick" over on the "American" Jaguar forum:
All very interesting but my post referred to yours and was NOT about the charging voltage. It as and is about the battery voltage after getting rid of surface charge. You should not have 2.3V per cell at that point.2.3-2.45 is battery charging voltage and the cell will stay at that voltage after the charger has been removed for a short time it takes 12-24 hours for a battery to equal out to its nominal voltage a charger should always give out between 13.8-14.5 volts lower and the battery will not fully charge and its life will be shortened as the plates sulfiate up
Dave
