Finally decided to post in the XJ section seen as I've now started to use it.
I have a 2006 XJ Sovereign TDVi which so far I've done the following to:
1) Found while front PDC seems to work well, when selecting reverse there is a three second audible warning and a red light on the roof console. I've kept the car in reverse with the ignition in position 2 and can detect both rear sensors at the ends of the bumper work well but the two sensors in the middle have not passed the 'clicky' test. Can't rule out sensors just yet though so will check PDC module for any issues at the weekend.
2) Car had a defective mirror on the nearside, had a gold tint to it so the electrochromatic layer had failed. Managed to source a replacement and got that changed over today and it's so much better having a decent mirror on that side, tested both heating and dimming and both working fine on all mirrors now.
3) Noticed the car never made any efforts to dip the mirror in reverse, but since changing the mirror it twitches when engaging reverse. Have cycled the mirror up/down and left/right several times for a few minutes (didn't take it back off as I know I had put some grease in when changing the mirror over) and the mirror now dips correctly when engaging reverse gear.
4) Had the EPB fault a couple times when I first got the car but it had recently had new discs and pads before I bought it. Did the brake pedal on and off and park brake on and off five times and it's seemed to cure it as it's always working fine now.
5) Earth clamp to battery was weak and had split which caused a bit of a panic but seeing how very easily the earth strap to battery is removed from the car I took the two 13mm nuts off the cable and brought it into the house to remove the old battery clamp and I stripped the wire back, tinned the cable and fitted a new heavy duty battery clamp to it, then heated it up with a mini flame torch and ensured the solder was well wet within it, refitted and battery giving good connection now.
6) Fitted LED bulbs for the main beam to replace the standard halogens, now the high beams match the bi-xenon dipped beam for colour and brightness.
Need to look into getting the JagDroid in a few months, temporarily using an FM Bluetooth adapter. Need to find the rare MiniDisc headunit or even more rare, MiniDisc changer when possible.
I did a lot of things with my X-Type on the forum but for the most part I don't think I'll be doing much messing about with this car as it's pretty much what I've always wanted as it is. Only things I can think of so far are:
1) Fit X358 front grill of which I have two, one brand new one used which is going to be painted to match the PEF the car is in.
2) Fit Jaguar boot lip spoiler. It's a minor styling thing but I like them.
3) Fit JagDroid unit, still looking into the pros and cons of these.
4) Get a set of wheels to have for summer use (19" Customs or 20" Sepangs). Keeping current 18" Rapier for colder months with appropriate tyres.
5) Replace standard halogen fog lamp bulbs at the front with some decent LED ones as they are utter garbage and possibly aiming too low so will also want adjustment which I presume will need to be done after car has been driven and with engine running to keep the height and level?
6) Investigate why when playing with the settings in the stereo the subwoofer adjustment seems to make next to no difference if at all, even though there is two alpine speakers in the parcel shelf.
So far though really enjoying driving the XJ and wish I had got one so much sooner. Always wanted one and finally have, it's not one of those "don't meet your heroes" type things. This car definitely is everything I was hoping it would be.
