LED Headlights - High beam replacements
2.9K views 25 replies 9 participants last post by  XJ50
Since my Jag was in the shop for a weekend (see coolant failure thread), I rented an Audi A5 in the meantime. This experience allowed me to compare my car to the loaner, and it made me realize that my high beams are not functioning properly. Initially, I thought they were simply dim, but after the comparison, I now understand that they essentially do not work at all.
What confuses me the most is that the low beams are incredibly bright, but only up to the cut-off. Once I switch on the high beams, there is practically no difference. I suspect a potential problem with the bulbs or something else.
Frankly, this situation is dangerous. I am essentially driving with only low beams, which is acceptable within the city. However, I live 15 minutes away from the city, down a winding road. During nighttime, I heavily rely on high beams in that area.
I have been searching for information about the non-matrix LED headlights, but the available information is limited.
I need to investigate the cause of this issue. The simplest solution would be to replace the high beam bulbs, but I am unable to find instructions on how to do that specifically for LED headlights. What type of bulbs do LED headlights use exactly?
#4 ·
Depending on the year of manufacture bulbs may not be replaceable. I could not change the bulbs on the LED headlights on my 2017 Portfolio. The headlights are a sealed unit and I had to buy a new one (not cheap).
Im not an expert in any shape or form but both full beams not working may not be bulb related. Could it be a fuse or indicator stalk related?
It might be worth, basis the cost of replacement headlights, hooking the car up to a diagnostic tool to see what, if any, errors appear.
#7 ·
LEDs don't use that much power and I'd be very surprised if there's a separate power feed for 'high beam'. It's not just a wire going to a bulb but rather a change to the beam pattern. Far more likely there's a signal or even can-bus command to the light units. If that's not working, then the cause may be software or maybe the switch? In any case, it's not a DIY type task. You need the proper diagnostic computer to trace the signals and commands running around the place. Given the cost of the components I'd be getting it checked by a specialist with the right kit or else a dealer.
#8 ·
Do you have a code reader to check for codes?
#18 ·
If this helps, when I swapped the Xenon headlights on mine for LEDs I made this video just to check if the AHB was still functioning correctly.
Reactions: JimC64
#19 ·
When you say LED, I am interpreting that as Matrix LED, not an LED bulb which afaik was never offered on a Jag?
Clearly if it's matrix then it's computer related as that controls which of the numerous bulbs are lit at any time to create the desired pattern.
Halogens have 2 filaments that they swap power between for low and high beam.
Xenons on the other hand have a mechanical flap that alters the beam pattern and the bulb is constant.
Clearly what system is in there has a massive effect on what may be wrong.
#20 ·
Have Jaguar ever fitted matrix LEDs? I don't think so. Mine are sealed LED headlight units but certainly not matrix.
Also, the headlights on my 2010 XF-S were Xenon but with a separate halogen high-beam (which I swapped for fan-cooled LEDs), not bi-xenon with the flap. I know that later models came with the bi-xenon system (including my 2015 XJ before I made the swap) and where the halogen high-beam had been became the LED indicator.
Reactions: jberks and JimboV8
